How to wiring Kickspace heater
  • jamesborn
    • Oct 2011
    • 14
    Simple question for which I couldn't find the answer:
    Can the fan in the kickspace be wired into the tankless water heater circuit, and if so, should I wire it before or after the emergency cut-off switch?
    Since the kickspace is often a ways away from the water heater I assume people usually wire them into different circuits, but since I in this case can wire everything on one circuit, am I allowed to?
    Would you generally wire a switch into the circuit so that you can individually power down the heaters, or is that considered overkill?
  • jamesborn
    • Oct 2011
    • 14
    nobody help me ... I understand kickspace heaters is new product
    • paul52446m
      • Nov 2009
      • 690
      Kickspace heaters or not a new thing, been around many years. Wire it to a circuit that is hot all the time and put a switch on it. It can be wired on a circuit with some thing else as long as you know what your amps are. Check amps of both units and you can use up to 80% of your breaker. Paul
        the kickspace heater can be wired into whatever you desire. if it is a manual switch you desire wire it that way. if you need the heater to come on when the boiler is running, wire it into a relay which turns on when the boiler kicks in. you can install a line thermostat with its bulb attached to the incoming water line so when the water temperature reaches a certain point it will kick in. so many variables, so many answers.
