110V thermostat
  • paul52446m
    replied
    Originally posted by pushkins View Post
    I have a condo that has an in wall HVAC system with ducting to the various rooms, the building has the huge fan units mounted on a lower level roof top.
    The thermostat on my wall is the original one with a mechanical dial and no way of telling what temperature it is actually set at. I want to change this out for a digital model and I'm told that the thermostats are 110V.
    An online search for a thermostat now has me confused as to what will and wont work.
    another way you could go if you don't find what you want. put a transformer and relay in the system and then you could go with any of the 24 volt stats.
    Paul
    replied
    a digital thermostat is usually low voltage for the control element while the switching network is a triac that operates at 120 volt. I'll look around and see what I can find and get back to you post haste!
    Thermostats & Controls We offer full line of thermostats and controls suitable for almost any application with varying degrees of control and programmability. Here is a listing of our most popular models. For more information, click on the thermostat model. Mechanical Thermostats: TSSHC-1-40/80F - Classic white double pole, 120/240/277 volt thermostat, positive
    started a topic 110V thermostat
    110V thermostat
