How to fix baseboard heat (gas heat furnace) making GURGLING NOISE?
  • Chicity
    • Nov 2012
    You can hear the noise in this video
    youtube DOT com/watch?v=NiFe92DUY7Q
    I've just bought the house so this is the first time i turn on the heat. Before that, I changed the thermostat to a HoneyWell Digital one. There was only 1 Red wire but there was no metal jumper connecting R and RC slot (does it have anything to do with this noise?). The heat comes out, everything works but the annoying noise is there. How do I fix this?
    Thank you
    p/s: i can't post link, please replace DOT with a .
  • Chicity
    • Nov 2012
    and the noise never stops as long as the heat is on.
    • brownie
      • Nov 2012
      Sounds like you need to bleed the air out of your system.
      • Brian_Martin_Parma_Air
        • Oct 2012
        • 7
        If it's a High Efficiency Furnace - This could be the cause
        it's the water in the inducer motor due to improper ventillation. pull the motor, drain it. howver, this will happen again until you ventilaate properl;y.
