Loose Vent Covers
    replied
    PUSHKINS is correct but by rights the side holes should be screwed into the wood. the fit should be an interference fit. sumbody was a little careless when he cut the vent opening. what you might try is cutting [drilling] a hole in the ends of the register and use a small countersink and use flat top sheet metal screws into the wood. paint the screws a matching white.
    replied
    Bend the little tabs on the white cover so that it grips the plastic a little tighter.
  • bearcat22
    replied
    thanks
    Originally posted by pushkins View Post
    Well, for a start the two pieces your showing should be attached, but if talking about the black grate part, it looks like a firm fit from your pictures however if it is loose also wrap some duct tape around the entire exterior perimeter, just enough to fill the gap between vent and register.
    Thanks. It is the white metal top piece that is the problem. There are many of these vents,and all the holes are a bit irregular.
    replied
  • bearcat22
    started a topic Loose Vent Covers
    Loose Vent Covers
    These metal vent covers do not fit tightly into the holes cut for them in the flooring. I need to secure them so they don't move, but need them to remain removable for vent cleaning.
ID:	87888Click image for larger version
ID:	87889Click image for larger version
ID:	87890Click image for larger version
