wall unit, pilot and control problem
  • jchealey
    • Nov 2004
    • 22
    Just had a repair guy out to fix a wall unit. He replaced the Robershaw controls and thermocouple. The pilot will not stay lit. It goes out after a few hours. In addition, the simple on/off thermostat does not turn the unit off, but will allow it to come on. If you turn the thermostat off and then bang on the Robershaw, the unit goes off. I was not impressed with Dr AC that came out and don't want to use him again. Any suggestions that I can check myself?
    Jerry
  • imeduc
    • 330
    Like him or not .He just sold you some controls tofix it and it dont work. Get him back.
    ED
    • Mike3
      • Nov 2004
      • 13
      Probably the last thing you would want to do at this point is attempt repairs yourself. Last tech could have left any number of problems. For instance whenever a gas valve is replaced you must clock meter to determine if furnace is burnng at rated input.
      • Troy
        Moderator
        • Jul 2002
        • 576
        These guys are right, be safe and make him finish what he started.
        Welcome to the forum!
        Try
        Try
