My fan will not kick on when I set the fan to the "on" position on the thermostat. I like the fan to blow in continous mode for even heating/cooling distribution so I set it to cac at the limit control thingabob inside the furnace. Also, when I shut the fan down to change the filter and then power it back-up I sometimes have to pull on the belt to get the fan going. I have an old G11 Lennox furnace with a belt drive blower. I'm not sure where to start to fix the problem. As near as I can tell there are no capacitors that could be causing the fan to need assistance restarting. I suspect a relay to be the problem for why the fan will not kick on when the thermo is set to on, but I'm not really sure. I'm also not sure if the fan motor itself could be getting ready to die. D[?]oes anyone have any words of wisdom?
mike fisher
fishermj@flcc.edu
mike fisher
fishermj@flcc.edu
