For example, if the thermostat is set at 68 and room temp is 67, the furnace will turn on for about 2 seconds and the thermosat will show that the room temp is now at 68.  Furnace will then turn off for about 2 seconds and the thermostat will show that the room temp is at 67 again.  This on and off cycling will continue indefinitely, along with the cycling of the thermostat reading.
It doesn't happen every time the furnace turns on, and when it does happen, I'm not sure exactly how long it lasts. I've never hung around to find out...I usually notice it as I'm walking out the door in the morning. Is this some type of relay problem maybe?
