Rheem Furnace Problem
  • rdlagess
    • Oct 2005
    My Rheem Furnace is 14 years old and is a high efficiency gas unit (I assume 80%). The problem is that when we set the programmable Tstat it comes on once. Then a motor in the furnace runs nonstop but the furnace heater will not come on again nor does the starter. When I shut it down and wait 10 seconds or so to restart, it runs properly. It may then run properly for 7 or 8 cycles then start to act up again. Can you tell me the cause?
    Bob LaGesse
  • lonestarheir
    • Jul 2005
    • 137
    Haven't you had problems with this unit for a while now? It sounds like you are having a problem with a relay or safety switch. Without more info on the unit, I would have a hard time telling you which.
    Brandon
    Brandon
    • SSN596
      • May 2005
      • 136
      Even a 14 year old heater, especially if it was designated as a "hi-efficiency" unit, has a fairly complicated control board. You need someone knowledgeable enough to study the control diagram and logically test the possible causes.
      • Fitter597
        • Nov 2005
        • 23
        Are you reseting it by turning the switch off at the furnace or by shutting the thermostat off and back on? And if you could supply a model number for the furnace which would be inside the top door, that would help alot.
