Can I wire this T-stat/sub-base to work?
  • KSever
    Home Inspector
    • Oct 2005
    • 95
    Currently have two thermostats operating, one for a/c and one for the boiler hot water heat and they are mounted side by side. The one for a/c is a round Honeywell and the other for heat is a cheap who knows what. I would like to get the heating and a/c on one stat.
    Now I have went and picked up a new subbase (Q539A1147 0532 which is suppose to operate heat and cool on different power supplies) for the honeywell stat. Problem is when I wire it the way the diagram shows with the subbase I can not get the boiler to come on. Here's the wiring I have.
    Cooling wires are Red, Yellow, Green
    Boiler heat two same color wires.
    Connections on the subbase are
    RH
    RC
    G
    Y
    W
    I have had these connected as follows and still no heat
    RH - boiler wire
    RC - Red wire from cooling
    G - Green form cooling
    Y - yellow wire from cooling
    W - other wire from boiler
    Will it make a difference which way the polarity is on the two boiler wires?
    I am now operating back the way they were until I figure this out on two stats
