I have a 16 year old gas furnace. I replaced the inducer motor assembly and now the furnace will ignite, the blower will come on for about 8 seconds and then shut off. It will do this 4 times until the temperature increases 1 degree on the thermostat. It's a 3 setting control. 50 to 150 and it doesn't seem to matter where I set the controls. Any suggestions?
Blower control
Tags: None
Does this behavior occur when the thermost is set at a nornmal room temperature of say 68-75 degrees?
Where is your furnace? Is it in some cold area where there is also a cold air return grill in this cold area?
Do you have a fan SWITCH, or does yours work off one of those solid state timer boards? IF you have a switch... you wouldn't happen to have the rectangular approx. 2 x 3 inch one made by Honeywell, that has the numbers on the dial, under the cover, that you can look at, do you? -
Originally posted by Gary MeyerI have a 16 year old gas furnace. I replaced the inducer motor assembly and now the furnace will ignite, the blower will come on for about 8 seconds and then shut off. It will do this 4 times until the temperature increases 1 degree on the thermostat. It's a 3 setting control. 50 to 150 and it doesn't seem to matter where I set the controls. Any suggestions?
Not quite clear what you are talking about - what is a 3 setting control? Why did you replace the inducer motor? What was your original problem??__________________________________________________
Brandon
- Have you changed your filter this month? -Comment
This occurs at normal temperature setting of 75.
The furnace is in a closet in the lower level of the house and does have a cold air return.
The blower control is similar to what you mention. It has a silver dial with 3 tabs you can adjust from 50 to 150. Off, off, on.
The inducer motor began making a noise and eventually siezed up.
The filter is clean.Comment
It sounds like a safety switch problem - at this point I think calling a tech out would be money well spent.__________________________________________________
Brandon
by hawkins111Toyotomi has dropped the fuel leveler pipe (20475952) for the Laser 56 heater from the inventory. This pipe was set up to include a fire safety valve...
Channel: Toyo Heaters
