I have cut the half inch clear plastic line to three inches as it passes thru my foundation. I have also bent it at a 45 degree angle so the water drips out of it. Any suggestions. Thank you, Kim
If it's discharging outside and it's above the frost line then there's not much you can do to keep a 1/2" line from freezing. You'll need to either install a larger diameter pipe to the outside, like 3 or 4" size or if possible try and redirect this drain line to an inside floor drain or perhaps a laundry tub
Has anyone had an occurrence of a Laser 730 or 731 over firing? The top of the heat chamber and the heat exchanger glow red on high when this occurs....
