I have a house built around 1956 with the original gas forced air heater. It has been upgraded with electronic ignition some time ago. It's been working great until 3 months ago.
The problem I'm having is that the unit won't stay on for more than a minute before the fan stops. I will hear the come on, then after about 50 seconds, it will turn off. After being off for a few minutes, it will turn on again. It cycles on and off like this, until the set temperature is reached, which of course, takes a long time.
I replaced the batteries to the thermostat, then I replaced the thermostat. This didn't help.
Any advice?
Thank you
Any advice?
Thank you
