Heating unit is freezing
  • doc2critters
    • Dec 2003
    I don't understand why but my heat pump unit is freezing the vent openings on two sides. The house is keeping temperature okay, but the unit sounds really loud when it cuts on.. Any thoughts as to what the problem could be. A Service man came out about a month ago and found some minor connectors that needed replacing. It wasn't working then. been working fine except noticed the freezing..
    Please help...
  • irregularjoe
    • Nov 2003
    • 176
    sounds like low freon.
    • doc2critters
      • Dec 2003
      [quote]Originally posted by irregularjoe
      I have the heat on, not the AC why would freon be an issue.
      • irregularjoe
        • Nov 2003
        • 176
        Freon is used in both cooling AND heating in a heat pump.
        And usually when you have icing on the coils it indicates low freon.
        Of course it could be other problems too, like a bad reversing valve.
