I had a new Coleman furnace installed last April. It does have a circuit board. My problem is that when the electricity goes off and comes back on, I get a surge that turns on the fan. The fan continues to run even with the thermostat off. The flashing lights that indicates the normallyclosed contacts in the rollout switch has opened. The furnace will not cycle. When I turn off the electrical switch on the furnace and turn it back on, the furnace resets and is fine. Is there any way to prevent this from happening? I would hate to be gone in the winter and have a power outage and come back to find a frozen house with only the furnace fan running with no heat. I called the installer and he did put a surge transformer or something on it and the problem still exists. He said to contact the electric company.
Coleman furnace electrical surge problem
Tags: None
Wht kind of sruge protector?
What kind of surge protector do I need? Where can I get one? Can I put it on the side of the furnace in line with the on off switch? does it matter which side of the line I put it on? Will any surge protector work like the ones for computers or is it a special one?Comment
Channel: Toyo Heaters
