I am hoping I can find a little assistance here in regards to me wonderful (when working) Lennox. Here in Georgia we have gone through a roller coaster of temperatures recently and it has had my AC and my heat cycling back and forth.
Here is the issue at hand. The heat has just recently been working and the AC just before that. Now yesterday my wife had the AC on and the compressor and fan outside were just humming along. Later on the wife said it did not feel that cool, so I placed my hand near a vent and by golly nothing was blowing. Then I went up in the attic, where our furnace unit is, and sure enough the fan was not on. So I went down to the thermostat and turned of the request for AC and placed the switch to off. Then I tried to turn the fan on manually and still nothing. While standing at the thermostat I figured I try to see if the heat worked and it would not fire up.
I then powered everything off, breakers, switch by the furnace and removed the upper and lower cover. I checked the tiny fuse that is on the SureLight board and it is good. I also checked to see if there was any voltage in the blower capacitor with my voltage tester. There was nothing.
I would appreciate any help that could possibly be given and I will be more than happy to answer any question someone may have to help resolve the issue. I can also do good quality pictures if needed. Thank you in advance for your time and consideration in this matter.
