Steam radiator vent
  • LiveFreeOrDie
    • Jan 2008
    Steam radiator vent
    Hello,
    I have a steam radiator that is always cold, and I'm guessing it's the air valves. Problem is I can't get the existing top plug air vent out to clean it, and I can't get the small middle slot screw out to install a new angle vent. Any thoughts on how to move forward before I start drilling and extracting things?
    Sorry for the very small picture.
    Thanks for any help!
    John
    chances are the steel pipe plug is "welded, rusted" in place. a 5/16" drill is the size for a one eighth inch pipe tap. I would center punch the plug and drill in progressively larger sizes up to the 5/16" bit. then run your tap in slowly. if it taps steel you'll have a spiral chip come out. if its in cast iron, the chips are just cast iron chips.
