Hello,
I have a Coleman Presidential II gas furnace (downdraft) model # 7700-856.
Here's what's going on (trying to be as specific as possible). It does have A/C attached as well.
When I turn the thermostat up to the desired temp, I do hear a "click" in the furnace, followed by the draft/combustion motor running. But the motor continues to run, and nothing else happens. The pilot does stay lit. My brother cleaned the burners off, and they look fine.
I'm thinking it's a bad centrifugal switch since the motor keeps running, and it's possible that the switch is never closing to open the gas valve.
The blower does work if put in Manual mode, but not on auto. So the blower motor is fine.
I was also thinking it may be the fan relay switch, but I have to still check if the burners light (I don't hear them lighting). My brother said he's getting 24vac to the gas valve, but said the furnace wasn't running???? Shouldn't there be NO voltage to the gas valve UNLESS the furnace is calling for heat? I will have to double check with him to see what he said.
What is the relationship of the transformer to the booster/combustion motor.
Does anyone have a wiring diagram? Another forum said a common sign of a bad booster motor/centrifugal switch (since they are not separate entities in this furnace) is that it would continue running and running. (which it does).
My brother is experienced with electrical/hvac, and I don't have much $$, but I wanted to ask if someone can help me troubleshoot voltages. A wiring diagram and/or sequence of events in the furnace would be helpful.
Thanks!![Smile](https://homerepairforum.com/core/images/smilies/smile.png)
Heather
Thanks!
Heather
