I have air in my hot water baseboard.
I'm having problems with a couple of the zones. The water and air can be heard moving through the system when the circulators come on.
I believe the air is the problem and resulting in not enough water moving through the lines.
I un capped the valve at the top of the air scoop and press the valve core down, but nothing happens.
I had problems a few months ago with excessive pressure, and a new flow control valve fixed that. I also changed the expansion tank and installed a new pressure release valve.
Everything seemed to be ok, but now with the very cold weather and most of the zones pumping I can hear air traveling throughout the system.
I have an oil fired peerless boiler with six zones, each on an independent B&G circulator.
Jack Hirleman
Jack Hirleman
