Need new 4 ton heat pump--Ruud or Carrier, or Maytag?
  • johneb48
    • Aug 2010
    I need a new heat pump system. Looking at the Carrier 25HPA648 2 speed compressor/FV4CNB006 VS air handler--16 seer Performance units. Anyone have one installed recently and what did it cost pre rebates and what were the rebate amounts?
    Also looking at Train and Ruud --any thoughts?
  • Home
    • Aug 2010
    Sizing an A/C unit
    What are you going by for that size of the unit? We just went from a 4 ton unit in our home to a 2 ton unit. It is doing the job nicely.
    Over sizing your system can cost more on the electric bill.
    We put in a Rheem.
    • johneb48
      • Aug 2010
      Actually, I decided on a 4 ton Rheem heat pump--I decided on the 4 ton unit because that is what the power company and all the contractors say I need.
        Oversizing a heat pump isn't just an electrical cost issue in fact that's the least of someones worries. An over-sized unit will no doubt cool and heat a smaller space very quickly problem is it doesn't remove excess moisture from the air before it turns off, many times leaving people with moisture problems in their homes.
        You need to remember that there is no rule of thumb, a system should be load calculated for your specific dwelling, an over the phone guestimate is just that a "guess" a good contractor will come out measure all appropriate rooms, with doors, windows all taken into account before sizing the unit.
        • 911Restoration
          Fireplace Woes
          by 911Restoration
          09-22-2026, 03:14 PM
          Laser 730 over firing
          by hawkins111
          Has anyone had an occurrence of a Laser 730 or 731 over firing?
          The top of the heat chamber and the heat exchanger glow red on high when this occurs....
          11-12-2024, 10:29 AM
