I have an old Coleman gas furnace, the kind under the floor with a floor vent. It says its model 2004C and has 70,000 btu in, 40,000 btu out. the old thermostat bit the dust. I have found a couple of mechanical heat only models. Should I be looking for a 24 volt or millivolt thermostat? How do I know what amp to look for in a thermostat? thanks a million.
whats a good replacement thermostat for gas furnace
Tags: None
reply on coleman gas furnace thermostat
I can't either. If it helps the serial # is 7651873. It could be 2004G i can't tell. but it's the old kind in the floor, it's got a small glass window on the top of it that lights up when it comes on. anyhow, i'm figuring a 24 volt, 2 wire mechanical stat will work, but i just don't understand the amp limits. i think the one i found was a 1.3 amp limit if i remember right. any words of advice on that info??
thanks a bunch.Comment
Our unit is about 12 years old and just needed another repair (capacitor this time, not too bad) but it's the third service call in two years. Compressor...
Channel: HVAC
