Announcement
No announcement yet.
Seeking Advice: AC Repair Question
  • Filter
  • Seeking Advice: AC Repair Question
    Hey everyone,
    I'm facing a bit of a dilemma with my AC unit and could really use some advice. Lately, it's been acting up – not cooling the room as effectively as it used to. I've checked the filters and they seem fine, so I'm wondering if it's something more serious. Should I attempt to troubleshoot it myself or call in a professional? And if I do decide to DIY it, any tips or resources you'd recommend? Your insights and experiences would be immensely helpful in getting my AC back to its optimal performance. Thanks in advance for your input!
  • #2
    If your AC is not cooling effectively despite clean filters, it could be an issue with the refrigerant levels or compressor. It's advisable to call a professional HVAC technician for a diagnostic to ensure safe and accurate repair, especially if you're unsure about handling AC components yourself.
    • #3
      did you checked the compressor with technician?
      • #4
        I hope I am not late to rescue you
        is there ice on the coil? it might affect the cooling
        on your own you can clean the dirt from the coil, check if there is any dirt there
