When A/C is used, in attic blower has started making squeaking noise
during spindown when outside temperature is below a certain level.
Blower appears to be a heavy motor with twin squirrelcages attached
on each side.
Does this type of motor need oil? I've never oiled in like 5 years.
Obviously it appears to be dying. How long will it last like this before
it starts making a constant noise?
Not sure how to get oil into the bearing since it would have to flow sideways.
Motor has some armored cable (steel conduit) leading from it
(perhaps per code) so I'm not sure how easy it will be to replace.
on each side.
