Model: RGDG-07EAUER
I have a gas furnace that I am trying to start up for the winter. It won't start up and I am trying to figure out where to start troubleshooting. The furnace last winter was giving me problems where it would run for a cycle and then shut down and not turn back on. If I reset the power it would continue with another heat cycle.
This year when I connected everything to fire up nothing happened when I set the thermostat. When I removed the IIBC cover I saw no status LED indicators (three LED's for this furnace). When I followed the flow-chart troubleshooting path the first place I came to was to check the LED indicator lights. If they aren't on then I need to replace the IIBC module.
Will someone please kindly direct my steps here? First is this the right place to start for troubleshooting? Should I be looking elsewhere first? I don't have the original manual to help guide me in this process.
Thanks in advance,
Thanks in advance,
