What's the most efficient way to insulate ductwork in an older home to improve heating?
Most efficient way to insulate ductwork in an older home
What's the most efficient way to insulate ductwork in an older home to improve heating?Tags: None -
Hi DK!
Insulating ductwork in an older house is a practical way to improve heating efficiency. Start by inspecting your current ductwork. Look for existing insulation and any obvious issues like gaps or leaks. It's important to clean the ducts before adding new insulation - this helps remove accumulated dust and debris. Next, seal any leaks you find. Use mastic sealant or metal-backed tape for this, as they're more durable than standard duct tape. Once that's done, you can move on to the insulation itself. Fiberglass duct wrap is a common choice. Look for insulation with an R-value of 6 to 8, depending on where the ducts are located. Measuring and cutting the insulation accurately is key. Wrap it around the ducts, making sure to cover all surfaces, and secure it with tape or wire. Focus especially on ducts in unconditioned spaces like attics or crawl spaces, as these areas are more prone to heat loss.
Don't overlook the vents and registers. Ensuring they're properly sealed to the ducts and walls can make a noticeable difference in heating efficiency. If you're not comfortable doing this yourself, especially in hard-to-reach areas, it's worth considering professional help. An HVAC technician can ensure the job is done correctly and safely.
This project might take a weekend to complete, but it can lead to noticeable improvements in your home's heating efficiency and comfort. You'll likely see the benefits in more consistent temperatures throughout your house and potentially lower energy bills. -
Should I use the same insulation in attics as I would in crawl spaces, or are there better options for each area?Comment
That's a good question. The insulation needs can indeed differ between attics and crawl spaces due to their unique environments.
For attics:
Fiberglass batts or blown-in fiberglass are popular choices. They're effective and relatively inexpensive. Blown-in cellulose is another good option, offering excellent coverage in hard-to-reach areas. If space is tight, spray foam insulation can be very effective, though it's typically more expensive.
For crawl spaces:
Moisture resistance is key here. Rigid foam board insulation (like polyisocyanurate or extruded polystyrene) works well because it's less susceptible to moisture damage. Spray foam is also excellent for crawl spaces as it can create a moisture barrier while insulating. Fiberglass can be used, but it needs to be properly protected from moisture to prevent mold growth.
In both areas, aim for higher R-values than you'd use for ductwork - typically R-30 to R-60 for attics and R-13 to R-19 for crawl spaces, depending on your climate. Remember, proper ventilation is crucial in both spaces to prevent moisture buildup. In crawl spaces, you might also need to install a vapor barrier on the ground.Comment
Channel: HVAC
