Bryant Furnace ignites, but no fan
  • TommyD
    • Dec 2010
    I have a bryant 376CAV. The burner ignites and stays lit for about 2 mins and then shuts down. The fan never starts. If I pull the service panel and press the panel switch the fan well come on but not the gas.
    Can someone guide me please?
  • paul52446m
    • Nov 2009
    • 690
    That sounds like the problem is in your electric board, the fan relay in the heat cycle is not turning on the blower. Can you turn the blower to on at your stat and then turn heat on and have it work? If you can then i would say it is a board problem. later paul
