Is epoxy a reliable fix for a leaking water geyser tank?
  • Annahmed
    • 223
    My water geyser had a leak, so I called someone to check it. It turned out that the tank inside was leaking. The person took the tank, got it welded, and reinstalled it, but after a few days, it started leaking again. When I complained, he came back, checked it, and applied epoxy over the leakage area. He mentioned that the tank is too weak to be welded again.
    Is epoxy a reliable solution in this case? Considering it’s a large water geyser, I assume the internal pressure would be quite high. For now, the leak has stopped, but I’m concerned about whether this fix will hold in the long term.​
  • TinyTool
    • 357
    Hi there!
    While epoxy can be a quick fix for small leaks, it's usually not the most reliable long-term solution for something under constant pressure and heat. Over time, the epoxy could wear down and the leak might come back. Given that the technician mentioned the tank is too weak to be welded again, it sounds like the internal structure of the tank might be compromised, which makes me think that a more permanent fix would be tough without replacing the tank. If the epoxy holds for now, it’s great for temporary relief, but I’d be cautious and keep an eye on it.
    For a more reliable fix, replacing the tank or the entire geyser would be the most secure option. Some geyser manufacturers also offer professional repair services that can replace the internal parts of the tank, but this depends on the model and age of your geyser. If replacing the whole geyser isn’t an immediate option, you could also try looking into specific tank repair kits that are designed for high-pressure applications. They tend to offer a stronger seal than general epoxy, but they may still not hold as well in the long run.
    Hope this helps!
    • Annahmed
      • 223
      Thank you for the thoughtful advice! I had a feeling epoxy might not hold up in the long run, especially with the heat and pressure involved. Replacing the tank does seem like the most reliable option, though it’s a bit daunting to think about the cost and effort.
      Do you think using a specialized tank repair kit would buy me enough time to plan for a replacement, or should I skip that and look into a new geyser right away?
      • TinyTool
        • 357
        A specialized tank repair kit could be a reasonable temporary solution, especially if the leak is small and you need time to plan for a replacement. These kits typically include epoxy resin or putty to seal the leak, sandpaper to smooth the surface for better adhesion, and sometimes a patch or clamp to reinforce the repair. While they can be effective for minor leaks, keep in mind that the heat and pressure in a geyser might limit how long the fix lasts. If the tank is old or the damage is significant, it’s usually better to start looking into a replacement right away. A new geyser will not only be more reliable but might also offer improved efficiency and features, potentially saving you money in the long run. If you decide to try the repair kit first, keep a close eye on the situation and have a replacement plan ready to avoid any inconvenience later.​
        • Annahmed
          • 223
          Thanks, TinyTool, for the detailed advice! The technician who worked on my geyser already applied epoxy over the leak, but I’m curious, how would a specialized tank repair kit differ from the epoxy he used? Are the materials or methods in those kits more effective for handling the heat and pressure in a geyser? Just trying to understand if it’s worth giving the repair kit a shot while planning for a replacement.
          • TinyTool
            • 357
            A specialized tank repair kit typically includes materials that are specifically designed to withstand the high heat and pressure found inside a geyser. These kits usually contain a heat-resistant epoxy resin, which is stronger and more durable than regular epoxy. They often also include fiberglass mesh or cloth to reinforce the repair area, helping to provide additional strength. Additionally, these kits come with a hardener to activate the resin and ensure proper curing, as well as surface preparation materials like cleaning agents or abrasives to ensure optimal adhesion. The key difference between a specialized repair kit and regular epoxy is that the materials in the kit are designed to perform under more extreme conditions, offering better resistance to heat, pressure, and wear over time. While both options offer a temporary fix, the repair kit is generally more effective and long-lasting than regular epoxy for high-stress environments like a geyser.
            Unless you're certain that the technician used a heat-resistant epoxy designed for high-pressure applications, it might be worth trying a tank repair kit. These kits are specifically formulated to handle the extreme conditions inside a geyser, offering better durability and resistance to both heat and pressure. If the epoxy used initially isn't up to the task, the tank repair kit could provide a more reliable fix in the short term while you're planning for a replacement.
            • Annahmed
              • 223
              Thank you for the explanation, TinyTool! Do you think I can handle the repair myself with the kit, or would it be better to call a professional again?
              • TinyTool
                • 357
                It’s something you can probably handle yourself, it’s not too difficult. Just follow the instructions: clean and sand the area, mix the epoxy with the hardener, apply it, and press in the fiberglass mesh. Let it cure as instructed. If you’re unsure at any point, though, it’s probably best to call a professional to make sure it’s done right.
                • Annahmed
                  • 223
                  Thanks for the detailed explanation! I appreciate the advice.
