I have an International Heater from the 50's in my home that won't turn on this morning. I jumped the thermostat wires at the stat and that didn't work, the pilot is on, the breaker is on, the emergency shut off is on, I can manually turn the fan on, but I can't get the heat on. Any ideas on where to start?
Old gas furnace won't start
check for power along the whole string going to the burner. does the pump/combustion fan work? does the ignition transformer spark? have you reset the protecto-relay? is there a blown fuse in the stat circuit? is the control transformer putting out 24 volts? -
You need to check for 24 volts at the furnace. Sounds like you ether have a bad transformer or a limit switch is open. PaulI have an International Heater from the 50's in my home that won't turn on this morning. I jumped the thermostat wires at the stat and that didn't work, the pilot is on, the breaker is on, the emergency shut off is on, I can manually turn the fan on, but I can't get the heat on. Any ideas on where to start?Comment
Channel: Toyo Heaters
