Monitor 422 sticky temp button
  • farmer4690
    • Jan 2015
    • 14
    Is there an easy way to free up my "UP" temp button on my heater.
  • FordMan59
    • Dec 2011
    • 355
    Could be the button and surroundings are just dirty and gummed up. You might try removing the plastic cover and cleaning the button/surrounding with a Q-tip and alcohol/cleaner. I've had problems with a button sticking on my 422 a couple times, but usually if I look closely I'll find the button assembly has slipped a little inside the heater top and is actually hanging up on the metal around the button. I've never looked, but probably to replace a button de-soldering the old one and soldering in a new one would be all there is to it. A switch similar to this is what is used for the buttons, but you'd have to find out the correct size. 100pcs Tactile Push Button Switch Tact Switch 6x6x5mm 4 Pin DIP | eBay Mathis Electronics in North Carolina will also do repairs on Monitor electronic boards, but if getting a button replaced is all you need you or someone else could probably do it much cheaper.
    • farmer4690
      • Jan 2015
      • 14
      Thanks, Fordman.
