Water Heater Installation - Need Advice
  • jovenac
    Banned
    • Apr 2026
    Hello everyone.
    I am planning to install a new water heater in my home and would appreciate advice from experienced installers or homeowners. I am unsure whether to choose a tank or tankless system, and I want to understand the basic installation steps, safety precautions, and cost factors involved.
    My current setup is quite old, and I am concerned about energy efficiency and water pressure compatibility.
    Are there any common mistakes to avoid during installation? Also, do I need a professional plumber or can it be done as a DIY project with basic tools and knowledge?
  • jovenac
    Banned
    • Apr 2026
    Originally posted by jovenac
    Hello everyone.
    Are there any common mistakes to avoid during installation, and when it comes to reliable service like Dependable Hot Water Essex County, is it better to rely on professionals? Also, do I need a professional plumber or can it be done as a DIY project with basic tools and knowledge?
    thanks in advance for any help
    • handyandy
      • Sep 2002
      • 210
      If you’re replacing an existing unit and keeping the same fuel type (electric for electric, gas for gas), a water heater install is very doable as long as local code is followed and the basics are right.
      A few key points to double‑check:
      • Permits & code: Many areas require a permit and inspection, even for a straight swap. It’s worth checking first.
      • Safety items: Make sure the T&P relief valve is installed correctly with a proper discharge line, and use dielectric unions if required in your area.
      • Electrical / gas sizing:
        • Electric: Confirm breaker size and wire gauge match the heater’s specs.
        • Gas: Verify venting, draft, and combustion air are correct—this is not a place to guess.
      • Expansion tank: If your system has a pressure regulator or check valve, an expansion tank is usually required.
      • Drain pan: Recommended (and sometimes required) when installed indoors or above finished space.
      • Flexible connectors: Braided water lines and approved gas connectors make installs safer and easier.
      If everything lines up with the existing setup and you’re comfortable with plumbing and (if applicable) electrical or gas work, DIY is reasonable. If venting needs to change, wiring needs upgrading, or you’re unsure about gas safety, that’s when calling a pro makes sense.
      Bottom line: water heaters are straightforward, but mistakes can be expensive or dangerous—so slow down, follow the manufacturer instructions exactly, and don’t skip the code requirements.
