How to add Utility Sink and Washer Drain to existing 4"
  • obriendigital
    • Mar 2011
    Hello,
    I am trying to add a sink drain and also a washer box. The black lines in the photo show existing infrastructure. I would like to install a sink and washer box. I am assuming I will need to cut into the 3 to 4" section with the cleanout and install some sort of T with a 2" out to the drain for the sink and washer. Where do I put the P trap or traps and also where is it best to vent. I also have a 2" pipe on the other side of the wall that could be accessed overhead for a vent. Could someone please help draw this out for me? Thank you!!!
    Tim
  • Redwood
    • Feb 2009
    • 512
    That existing pipe... What drains down through it?
    Kitchen Sink Maybe?
    Now I can Plumb!
    • obriendigital
      • Mar 2011
      I sink on the other wall for a bathroom and I think it's a vent too
      • Redwood
        • Feb 2009
        • 512
        Do any fixtures from the floor above drain down through that pipe?
        In others words does water ever come down that pipe you are planning to tie into?
        Now I can Plumb!
        • obriendigital
          • Mar 2011
          Yes, i did find out that 2" is a drain. Darn!
          I also have a photo of the new cleanout and T to put into the 4" to 3" stack. Is this ok? The 2" will run around the corner to the sink and washer.
          The other photo is ultimately where I want the sink and washer.
          Lastly, there are a couple photos of the stack towards the ceiling, it looks like the left part of the Y is the main vent, can I tie into that with a saddle or 3" with 2" out to 2" then over my wall to work as a vent?
          **Note, the photos got turned somehow. The last 2 should be rotated as the stack goes up to the ceiling.
          • Redwood
            • Feb 2009
            • 512
            Sorry I meant to say 3" in my post above...
            Your 5th picture is turned and missing the labels you had on it over at Terry Love's
            No you can't use a saddle on what you think is a vent...
            I'm pretty sure that something drains in that too!
            What does?
            Now I can Plumb!
