Propane water heater vs. Electric
  • gasman
    • Apr 2011
    My propane water heater is 15 years old and I figure its time to replace it. I have a propane furnace and range. The price of propane has SKYROCKETTED to $3.20 a gallon. Im thinking I should replace the water heater with a 50 gallon electric. I know its not as efficient, but at these gas prices Ive got to something to lower my gas bill. So should I go electric on my new water heater?
    the choice is yours. the recovery rate is way below that of a propane and oil fired burner.
    • rmw
      • Mar 2011
      • 54
      Electric is actually 100% efficent in that all the heat is delivered from the heating element to the water.
      It does not heat as quickly and so you must generally have a larger tank for the some amount of gph out put.
      If you have a old propane heater I would sugest a new high efficancy model 90%+ on demand system you would see a savings over normal propane or electric as somwe of your largest loss is just stand by loss keeping 50 Gallons of water hot.
      You may want to do a cost comparison based on your power rate vs a high efficancy gas. then decide if the highefficancy gas is worth the extra upfont money.
      • Redwood
        • Feb 2009
        • 512
        Efficiency and cost are 2 different things...
        Now I can Plumb!
        • gasman
          • Apr 2011
          If I can figure out if the electric water heater is just a little cheaper the gas is OUT. The price for LP at $3.30 a gallon is highway robbery.
          • Redwood
            • Feb 2009
            • 512
            Where are you located?
            In some areas of the country heat pump water heaters can work quite well.
            Now I can Plumb!
            • gasman
              • Apr 2011
              Im in the western NC mountains. We have some pretty cold winters. Are you talking about the same heat pumps that are used to heat homes?
