Sulfur / Iron Filter
  • Kidd6488
    • 110
    Hello everyone! Been quite a while since I've been around these parts, but I
    have a question, hoping you can help!
    At my parents' house, their well was probably dug a little too deep, and they get
    a moderate sulfur smell in their water sometimes. A culligan man came out and
    inspected the water and everything, and said there is also suspended iron/rust in
    the water. He recommended the following system be installed:
    CULLIGAN - sulfur cleer whole house water filter system
    However, they wanted $2600 for it (including installation)! This was much, much
    higher than we'd expected. So my question for you all is, where can we buy a
    comparable system and install it ourselves?
    There are different kinds of filters, and I'd be curious to know all of your
    opinions on these systems. One of the popular kinds for example, is the
    Manganese Greensand Filter.
    Any type of info you could provide would be appreciated!
    ~Jonathon Reinhart
  • Redwood
    • Feb 2009
    • 512
    Culligan tends to be much higher in price than many water conditioning systems...
    SpeedBump will be along shortly I'm sure he could fix you up with a very nice system substantially less than the Culligan system...
    Now I can Plumb!
    • Speedbump
      • Aug 2010
      • 293
      The Culligan man wants to get his cut as well as the salesman and the guy that built the unit. And they are high for sure.
      The sulphur system we use here in Florida is here:- PumpsAndTanks.com
      As for the iron, I like the manganese greensand filter, and if your using the sulphur removal system we have, you don't need an oxidizer as the air in the sulphur removal system will take care of that for free. Both of these units would be much less than the Culligan man's one unit, but the install may be a problem for you.
      I always caution people about units that claim to do more than one job. This usually means it does half a good job for both.
