How to remove kohler k-393 Cartridge
  • q0987
    • Aug 2011
    Hello all,
    I have the k-393 faucet and need to replace the damaged cartridge 77006.
    (i.e. kohler GP77006-RP Kohler CCW Valve Kit )
    Please check my attached picture as follows:
    Can someone tell me how to remove it correctly?
    use a deep well six point socket and ratchet. according to the schematic, that hex fitting is the only thing that holds the cartridge in the valve body. it may seem like it won't move, but its brass to brass. go slow with it.
    • q0987
      • Aug 2011
      Hello , I have drawn two red arrows on the picture. The first one on the left points to "part". The second one on the right points to "base".
      When you say "hex fitting", do you mean the "part" pointed by the first red arrow on the left?
      Or I should loose the part just above "part" pointed by the first arrow.
      If I have to loose "part", I found the bottom of the part is smaller than the "base" as indicated by the second red arrow on the right. No matter how hard I rotate, it just cannot come out. I worry that I may break it.
      By the way, as shown in the picture, I didn't remove 1087748 Shroud. So do I remove the "hex fitting" from top of the forcet or from the bottom of it. If I have to remove it from the bottom part, then i have to remove 1087748 Shroud.
      thank you
      • Redwood
        • Feb 2009
        • 512
        The top red arrow is where you put the socket wrench and turn it...
        Now I can Plumb!
        • q0987
          • Aug 2011
          Hello Redwood,
          Can I directly loose it and take it out from the top without removing the base 1087748 Shroud?
          Thank you
          • Redwood
            • Feb 2009
            • 512
            It should come out without removing that...
            The part you are seeing as too big is actually the 1094155 yoke supply...
            Now I can Plumb!
            • q0987
              • Aug 2011
              Hello Redwood,
              It is quite strange whenever I try to counter-clockwise rotate the 77006, in fact I move the 1094155. It is very tight.
              Question 2> Which one I should buy 77006 (Counterclockwise Close) and 77005(Clockwise Close).
              My damage one is on the right side and I use Counterclockwise to close. Does it mean that I should buy 77006?
              thank you
              • Redwood
                • Feb 2009
                • 512
                The clockwise and counter clockwise refers to the direction you turn the handle to shut the faucet off...
                Not the direction you turn the nut to remove the cartridge...
                Now I can Plumb!
