in wall drain pipe repair
  • Welbourne
    • Aug 2011
    I know what I need to to, to lower the drain out from a bathroom sink but I do not know how to put a new T in the existing pipe in the wall.
    I am replacing a regular sink with a laundry tub in the 1/2 bath in the garage and the drainout is higher than I can use for the laundry tub drain.
    I am working with PVC pipe, I assume, as the house was built in the 80's.
  • Redwood
    • Feb 2009
    • 512
    What you have to do depends on what is hidden in the walls.
    You can neither assume PVC or, what you have for a configuration in the wall until you open it up.
    Can you see white plastic pipe inside the wall>
    With the existing trap removed can you feel the turn of the pipe or see it inside the wall? Does it turn left or, right, or go vertical?
    Now I can Plumb!
    • Welbourne
      • Aug 2011
      drain pipe repair
      Thanks for the responce. The drainout now is high on the wall and I can see that the vent pipe goes down. I am pretty sure it is PVC but understand I need to cut wall and make sure.
