I want to buy a house that has a strange problem with a tub drain basket. The basket is plastic and it looks like it has been melted with acid. What caused the disintegration of the basket? Could a drain cleaner do this? Would the PVC drain piping under the drain also be damaged? How can a home inspector do a 'non-invasive' inspection on this to determine the extent of the damage? Suggestions?
More info:
The tub is on the second floor and there is no access to inspect under the tub. If we run water into the tub to see if the drain piping is leaking by checking the first floor ceiling, it will probably leak all around the basket anyway. Click on the photo to enlarge:
Thanks for your suggestions,
Warren.
More info:
Warren.
Draino claims their product is "Safe on: All pipes and plumbing systems". It looks like someone poured battery acid down the PVC tub drain. There are also burn marks on the vinal floor in the kitchen - like the idiot also spilled some acid there
