Fiberglass Tub Enclosure Cleaning??
  • DD716TED
    • Nov 2004
    • 220
    I am cleaniing a home to rent and tjhe fiberglass tub/shower enclosure is a mess.. It has excessive built up soap scum along with other discoloration due to shampoos or something... I have tried almost every shower cleaner on the shelf at the grocery store with little or very limited success... What can you use to thououghly clean a fiberglass tub / shower enclosure?
  • Redwood
    • Feb 2009
    • 512
    Try This...
    3M Marine Color Restorer
    Restores color to your gelcoat
    Resurrect the gloss in your boat's gelcoat with this compound/polish that combines an exceptionally fast cutting compound with a finishing material that removes the fine scratches that compounding normally leaves behind. Removes light to heavy oxidation, scratches, stains, and other blemishes from fiberglass gelcoat.
    Contains no wax or silicone
    0.52qt.
    Works on tubs too...
    Now I can Plumb!
      "Gel Gloss" works too.
      • Redwood
        • Feb 2009
        • 512
        Yep! Pretty much anything designed to make a boat pretty will do nicely on a fiberglass tub....
        Now I can Plumb!
