I have wondered why my washing machine sometimes overflows back out of the drain rarely but enough to be irksome. I never could figure out why as it seems to drain nicely whenever anyone stands around by it but nonetheless it sometimes dumps a couple gallons on the cement floor.
The machine is located in the basement of ranch style house and located right next to the stand pipe with both shower drains located right above within 15' on the ground floor above. No special hookups here just regular elcheapo Whirlpool and everyday water saver showers upstairs. The washers drain hose has a holder and is fully seated in the pipe and normally drains quite well.
I wondered long and hard what caused this just sometimes but today happened to be there when my wife was in the shower and it started to drain. The water came pulsing out like it was under some fairly stiff pressure back out of the top of the washers drain line. Of course now that I know what "seems" to be causing it things bear a bit more watching but is for now can someone explain what is causing this?
