Garbage Disposal
  • xxxsheridan
    • Mar 2004
    • 7
    Garbage Disposal
    Someone please help, I have put rice and chicken dowm my garbage disposal and it has clogged up the sink. How do I repair it, or do I call a plumber ?
  • kactuskid
    • Mar 2004
    • 801
    You should remove the trap under the sink and clean it out, you may also need to snake out the drain that goes into the wall. Is your disposer clogged too. There is a hex wrench that came with your disposer. With the power off, stick the end of the wrench in the slot underneath the bottom of the disposer and turn it left and right to try to free the clog, then turn it on and run cold water thru. If all this doesn't do it then time to call a drain router company, they'll be cheaper than a plumber if all your under the sink plumbing is clear. Here's a link for details: http://www.acmehowto.com/howto/homem...rfix.htm<br />
    Hope this helps.
    • xxxsheridan
      • Mar 2004
      • 7
      Thanks,
      Mu disposer is working fine, how should I remove the trap ?
      • kactuskid
        • Mar 2004
        • 801
        You'll need a pipe wrench and a bucket to catch the matter underneath the sink. Here's a link to give you all the scoop:
        Thanks,
        • xxxsheridan
          • Mar 2004
          • 7
          Thanks you are the best, Ill let you know how it turns out..:-)
          • kactuskid
            • Mar 2004
            • 801
            Good luck
