I have an Aquasource Pull-Down Kitchen Faucet. The manual lists:
Item 0328012
Item 0328011
Model 65710N-B8303D2
Model 65710N-B8327H2
I'm not sure which applies, though the difference appears to be if it comes with a Escutcheon or not is all.
I think that answers the questions that I usually see in forum threads.
Any help would definitely be appreciated!
Item 0328012
Item 0328011
- No other plumbing does this.
- If the hot water is on partially, it doesn't occur.
- It occurs every time.
- If I hold down the spray button on the faucet it usually doesn't occur but sometimes it does. This model sprays from the same area as it pours and doesn't have an independent spray hose/fixture.
- If I turn the hot water supply off under the sink and then turn the hot water faucet on, it doesn't make any noise (obviously)... but with the slightest amount turned back on at the supply, the banging starts again.
