I put in a pex radiant floor heating system in my new concrete slab sunroom, and the hot water system that it is connected to (that heats the whole 4 story building) does not stay on long enough for it to circulate through the floor. My plumber put on a separate pump for this pex line, but I think it only runs when the whole system does, which is not long enough.
Is there a way I can set up a separate flow system that can run longer than the boiler, that can continue to circulate the hot water in the system?
Thanks, MIke
Thanks, MIke
