Question! Can I use it for plumbing repair?
  • Ricky
    • Jun 2013
    Does anybody know anything about this repair technology? RecentlyI found this thing and wondering if I can use it for plumbing repair.
    Go to indiegogo com (type in search box) ultimate hermetic soldering tool
    I want professional opinion on this. Thanks much.
    posting
    To begin, something wrong with the url. I cut n pasted the link into my browser and nothing related to plumbing showed up.
    The second thing, [ultimate hermetic soldering system] again nothing showed up for your intended purpose.
    What did show up is an exothermic bonding using a eutectic alloy, which goes from solid directly into a liquid and back again.
    • Ricky
      • Jun 2013
      Go this website – indiegogo (dot) com then type in website searchbox - uhst
        went to where you said. typed in uhst into search box and three pages of something in german came up.
        be more specific
        • Ricky
          • Jun 2013
          They are not allowing me to post direct link here! What can Ido then?
          UHST - UltimateHermetic Soldering Tool on Indiegogo . com
            So basically your trying to direct people to a web site to get them to by this UHST ?
            The answer to your question would be NO you cannot use this product to repair plumbing, even if it did work, even if it was able to be used on potable water, even if it was able to be used on pressurized water lines how would you heat up the interior of a pipe on the inside of the hole to apply the stick to the exterior of the hole?
