Can I use S&D for DWV in wall?
  • fuzzymaster
    • Dec 2014
    • 6
    I would like to not cut the wall open, and wondering if I could use 3" S&D pipe in wall . They make the bushing to connect sched 40 to S&D so would be all glued. Thanks
  • akaothermick
    Absolutely incompetent
    • Jan 2014
    • 140
    It's your wall, not getting it inspected you can do whatever you please, but its not code in my locality,
    • fuzzymaster
      • Dec 2014
      • 6
      I am going to see if I can order a stick of sched 30 from local supply house, I think that will meet code.? I would rather do it right even if the S&D would work.
      • akaothermick
        • Jan 2014
        • 140
        Use furring strips on the wall out to get the room to fit the 3' sch 40 DWV if you cannot fit it in the wall,
        • fuzzymaster
          • Dec 2014
          • 6
          The point is that I don't want to cut the wall out. I am adding a second story toilet in attic space I am finishing off. After checking, sched 30 is not in code either.
          Sched 40 3" = 3.50 OD
          30 3" = 3.25" OD
          S&D 3" = 3" OD
          Just for some reference.
          • akaothermick
            • Jan 2014
            • 140
            Kind of looks like what you want to do, is not possible, and meet code.
            • fuzzymaster
              • Dec 2014
              • 6
              Yea, that's what I am seeing, but in practical sense, what could be the downside of using S&D in a wall?
                Codes are there to protect two groups of people:
                1: you as the homeowner from a bad contractor
                BUT most importantly
                2: the next buyer.........................they have no idea what anyone before them did, they trust it was to code and rightfully so.
                When in doubt.......Do it right ! cut the wall and install sch. 40 3" it's not that big a deal to re drywall or repair the cut out section.
                • fuzzymaster
                  • Dec 2014
                  • 6
                  But theoretically, it would work just fine.? I get the codes, I have had to work with them. Thanks for all replies, very helpful site. Glad I found it.
