PVC to galvanized steel?
  • mjsiemer
    • Apr 2003
    Hi all-
    This morning I discovered that my tenant poked a hole in the drain pipe under her sink. So I get to fix it when I get home
    My question is, is it possible/advisable to connect PVC to galvanized steel? All the piping under her sink is galvanized steel (old house). Is my best bet to just get a replacement piece of PVC and connect that to the old piping? Will that work okay? Or, should I just take out all the galvanized and use all PVC?
    If I need to use galvanized for some reason, do they still make that?
    thanks for your thoughts,
    Matt
  • Troy
    Moderator
    • Jul 2002
    • 576
    I don't think I can answer definitively, but when the plumbers replaced a section of my steel pipe a few weeks ago, they replaced it with pvc. They connected the pvc to the steel, and it is working fine. I think it is an acceptable practice.
    Let us know how it goes.
    Try
    • EasyE
      • Jun 2003
      • 17
      Yes you can Connect PVC/CPVC to Galvanized or Steel pipe.
      Also if you have copper and want to connect it to Pvc/Cpvc they sell a fitting called Genova fittings it works great connecting the 2.
