When the house was built, the remote sprinkler system valves were connected to the water supply between the water meter and the under house pressure regulator..At that time the city water supply was slightly over 80 PSI... all worked well UNTIL the city upper the water supply pressure to about 120 plus... Now this pressure seems to great for the Rainbird Electric Anti-siphon sprinkler valves and they hammer (thump, thump, thump, thump) when electrically shut off... Is there and easy way to correct this or do I have to dig up a portion of the supply line and install a pressure regulating valve in the yard? The sprinkler system can be isolated from the water supply by a ball type valve.. will throttling this valve have any impact on pressure???
Hammering Electric Sprinkler Valve
