I flush my toilet and it flushes find, but I have to jiggle the handle to get the water to stop running what do I do?
My toilet sucks.
Jellybean,You have to lift the lid off of the water tank (the back part that has the handle on it) look inside and you will see that your flapper isn't closing after the toilet has flushed. The fix might be as simple as adjusting the chain that is attached to the flapper. look inside and let us know what you find. -
Remove the flapper and replace it. Inspect where it seats to the flush valve to insure there isn't any residue rubber from the old flapper. Replace the handle if it looks questionable. TIP: I ware latex gloves when I handle old flappers due to the deteriorating rubber is hard to scrub off your hands and makes a big mess. [xx(]quote:Originally posted by jellybean
