First time ever on a forum!
We have a house on its own well with low water volume. The pressure switch is set to come on at 48 lbs, turn off at 68 lbs. The pressure tank is an 85 gallon unit set to 46 lbs. From the tank the whole house was 1/2" copper. I'm changing the main lines, cold first, from the 1/2" copper to 3/4" pex a little each day so we have water every night. We now have even less volume from every tap since I started this project....The cold lines are now finished with 3/4" pex running to within a few feet of each tap, from there its back to 1/2". Water volume is still down from when I started and I don't understand why or how to correct it. I seem to be going backwards. The problem of water volume dropping when more than one tap is on has been resolved. Is there something I missed or did wrong? I"m reluctant to start the hot water lines in case I further reduce the volume! Thanks.
