Not sure where this fits, but it is a sort of plumbing issue....I need a new pressure washer hose/wand for the pressure washer. I see a lot of M22 and other M type fittings called out, but...what do I order? Since I replaced the pump some years ago I have no idea of the manufacturer. The male threads measure about 14.5 root diameter and maybe 16.5 or so major diameter. How do I find the right nomenclature?
'Sort-a' plumbing issue....
Tags: None
It sounds like you’re navigating a bit of a puzzle with your pressure washer fittings! Since your measurements point to a male thread size around 14.5 mm root diameter and 16.5 mm major diameter, it’s likely you’re dealing with an M22 fitting, which is common for pressure washers. M22 fittings can vary, so you might want to double-check if you need a specific pitch like M22-14 or if quick-connect fittings are involved. If you’re unsure, local pressure washer dealers or online fitting guides can be a big help, and don’t forget that adapters can be a handy solution if things don’t match up perfectly.
