Repair of cast iron plumbing
  • installrite
    • Jun 2004
    How do you pull a cast iron waste pipe apart at the joint?
    I am refering to the old style. Is it a lead type sealant they used?
    Can I pull it apart by heating it up?
  • Hube
    • Nov 2003
    • 453
    The old way to make this joint was to stuff in Oakum around the pipe, then pour molten lead in around it.(to remove,just reverse the procedure) You will need to melt the lead with a torch. Is this joint a vertical or a horizontal?
