How do I remove shower Kohler divertor that leaks
  • mwmwmfilms@yahoo.com
    • Jun 2004
    I have a shower/bath that has three knobs Hot, Cold, Divertor. When you try to divert the water from the
    bath to the shower half of the water continues to run to the bath, making the shower pressure very weak.
    I have removed the knob and the stem nut and gently (as not to break anything) tried to screw out and
    also pull straight out the stem, to no avail. I figure there are lime deposits on the inside of this divertor.
    Would it be possible for you to instruct me on the proper technique on removing the divertor so that I can
    proceed with confidence. That way if I still break something I will know that I was at least using the right
    technique.
    Thank you for you assistance
    PLEASE email me any responses to chris at mwmwmfilms@yahoo.com
  • kactuskid
    • Mar 2004
    • 801
    Here's a link that'll show you the breakdown of how to remove your divertor parts
    http://www.terrylove.com/pp_3.htm Though I have a suspicion you've already seen this.
    Use some PB Blaster to spray on the parts to free them up, find it at most hardware or auto stores
