I have a single handle shower and the handle very recently broke. The molded plastic cracked so that it would no longer grasp the copper to turn it off and on or hot to cold. I have been using pliers to operate the shower (until I can replace it) -- the other evening I showered and went to bed -- in the morning I discovered that the shower had turned itself on. I turned it off 3 more times before finally it stayed off. What is wrong with it? Just prior to this (previous day) I had a horrible time getting the water to even shut off. I have to remember which direction and how far I turned to get the water on so that I can turn it back off. I have a feeling that I am not going to be able to just put a new handle on it to fix this. Does it have something to do with the alignment of the valve, such as turning it one way or another so that it lines up with what should be hot on one side and cold on the other? Did I just not catch the threads when I tried to turn it off?
Helpless in AZ [8]
Helpless in AZ [8]
